Thread: Jandy Check Valve rusted spring
    Jun 2014
    Florida
    Default Jandy Check Valve rusted spring
    Does anyone know of a replacement spring that can be purchased for Jandy Check Valve. "thanks for your input"
    Default Re: Jandy Check Valve rusted spring
    I don't think the spring alone is available. Here's the assembly that fits most current Jandy check valves:
    Zodiac 7056 Cover with Flapper Assembly Replacement Kit
    However, if the spring truly did rust . . . you need to figure out why. Something is wrong, since that's a stainless spring!
  1. Rattling Check Valve
    By nomar116 in forum Pool Equipment & Operations
    Last Post: 04-07-2013, 07:58 PM
  2. Jandy valve ... water getting past closed valve
    By Longgrove in forum Pool Equipment & Operations
    Last Post: 06-13-2011, 02:59 PM
  3. Can a leaking Jandy "Check Valve" with clear top be "fixed"?
    By 105ex in forum Pool Equipment & Operations
    Last Post: 05-29-2010, 09:17 AM
  4. Question on Jandy 90 degree check valve.
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-06-2007, 07:46 PM
  5. Check Valve
    By jrv331 in forum Pool Equipment & Operations
    Last Post: 05-30-2006, 09:39 AM
