Thread: Cya
    Sunny32504 is offline ** No working email address ** Sunny32504 0
    dallas,texas
    Default Re: Cya
    Iv'e never had to buy a product to raise CYA. Do 3" tablets contain it. What is the name of the product so I can go to the pool store and just go in grab , pay and run for the hills.
    Default Re: Cya
    You can just use some triclor tabs for awhile. They contain cya in them. You can use them for awhile, but monitor your cya level. When you get around 40, you should then switch to just using bleach. They are also very acidic, so if you have low ph, you might not want to use them. Another option is to just buy some cya. It is sometimes called stabilizer or conditioner. Check the ingredient label, and if it says cyanuric acid or isocyanuric acid, that is the right stuff. You can usually find it at Walmart, Lowe's or Home Depot or at a pool store.
    ScottS is offline Registered+ Thread Analyst ScottS 0
    Covington, LA.
    Default Re: Cya
    3" Tri-Clor tabs do add CYA.
    If you need to add CYA you are looking for what is often labeled as "Stabalizer" which is cyanuric acid. For example at WalMart HTH sells this in the same section with pH up, pH down, pH sideways (haha <--- just kidding not sideways), Alk up, etc. It is in the same looking container.
    dallas,texas
    Default Re: Cya
    Okay I will try tablets until I can go get some stabalizer
