First of all, get a good kit. We call test strips 'guess strips' for a reason. The test kit that we think is by far the best is the Taylor K2006 or 2006C (better buy). Not available locally but you can get it through this link that takes you to Amazon: http://pool9.net/tk/
But, in the meantime, go to Walmart and see if they have the HTH 6-Way drops-based kit (no test strips!) and get that. If they don't, get an OTO/Phenol Red kit (yellow and red drops) instead. Use it to test and then post your numbers. Also while you are at WallyWorld, get several jugs of their generic 8.25% bleach and a couple of boxes of 20 Mule Team Borax (laundry aisle).
Your SWCG manual should have a specific requirement for a CYA level for that unit.
For reference, in a 40K gallon pool, each of the 121-oz. jugs of 8.25% bleach (Walmart's generic is fine), will raise your FC by about 2ppm. How high you need your chlorine level to be depends on your CYA level. More info at this link: http://pool9.net/cl-cya/
(Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
Welcome to the Pool Forum!
