Thread: another pool season starts
    Jun 2014
    Canada
    Cool another pool season starts
    hello fellow pool enthusiasts!
    I read through a some posts a few years to bring up my knowledge of pool chemistry. This is one of the few places where you can get real pool information.
    Right now I want to upgrade to a variable speed pump. I have a Sta Rite 2HP which has lasted for many years, so I want similar quality and want to benefit from variable speed economy and I believe better filtration (I'll find out soon).
    Enjoy the pool season (a short season fro Canadians)
    Default Re: another pool season starts
    If you're going to do it yourself, this is probably what you want:
    Hayward SP3400VSP EcoStar VS
    and this:
    Intermatic PS3000 Pool Surge Protector
    But, you'll need to check: in the US, Pentair has cut their warranty on do-it-yourself installations back to almost nothing. That might not be true in Canada. Or course, if you hire it done by a pool guy, he'll buy it (I assume) and the warranty problem won't be an issue.
    Regardless, get a surge protector. The VS pumps are NOT as reliable as the pump you are replacing, and sensitive & very expensive electronics are the reason.
    Also, if you can put some sort of cover over the pump so it doesn't get rained on, that might be a good idea. I've seen reports of water infiltrating the electronics.
    But, do NOT compromise pump ventilation! Shade? Good! Rain cover? Good! Reduced airflow? Very, very bad!
    Just wanted to pop in and say hi and welcome you to the Pool Forum!
    p.s. I like your username!
    Jun 2014
    Canada
    Thanks for the nice welcome and good info.
  1. huge blast of air when pump starts
    By poolgal13 in forum Pool Equipment & Operations
    Last Post: 05-18-2014, 09:41 AM
  2. Motor hesitates and then starts
    By pbradley0 in forum Pool Equipment & Operations
    Last Post: 09-29-2012, 02:55 PM
  3. Sand Filter Starts - Emits White Cloud
    By MattTexas in forum Pool Equipment & Operations
    Last Post: 07-08-2012, 09:34 PM
  4. Pool closed for the season
    By Sprocket in forum Dealing with Algae & Slime
    Last Post: 05-22-2008, 09:57 PM
