Re: cloudy darkish water
PoolDoc recommends running the filter 24/7 when trying to clear a pool. Green tinted water with 0 combined chlorine is usually an indication of metals in the water. Do you fill with a well or city water? Have you added any algaecide lately? Is there copper in your "Super Chlo"?
You might want to do a DE test on your filter
http://pool9.net/de-test/
Some of the Walmarts around here carry 10 lbs. HTH D.E. Filter Aid
http://www.walmart.com/ip/HTH-D.E-Fi...10-lb/20434370
The picture is wrong, the description is accurate.
Pappy
