I can't answer most of those questions but will tell you that you want to get your water balanced before you turn on the unit. Do you have a drops-based test kit? Can you post current readings?
Also, disconnect the copper electrode that is on the unit. Contrary to popular belief, it is not chlorine that stains pools and turns blonde hair green, it is copper!
