Results 1 to 10 of 18
Thread: HELP - Saltwater System Inital Setup - Intex 54601EG
    QiingGuy is offline Registered+ Thread Analyst QiingGuy 0
    Jun 2014
    Las Vegas
    Default Re: HELP - Saltwater System Inital Setup - Intex 54601EG
    @watermom I don't have drops but I have strips, will that work?
    Jun 2014
    Las Vegas
    Here are the strip results:
    TH - 1000
    FC - 0/0
    Ph - 6.8
    TA - 120
    CYA - 0
    Well, we actually call them 'guess strips' around here......
    The test kit that we think is by far the best is the Taylor K2006 or 2006C (better buy). Not available locally but you can get it through this link that takes you to Amazon: http://pool9.net/tk/
    But, in the meantime, go to Walmart and see if they have the HTH 6-Way drops-based kit (no test strips!) and get that. If they don't, get an OTO/Phenol Red kit (yellow and red drops) instead. Use it to test and then post your numbers. Also while you are at WallyWorld, get several jugs of their generic 8.25% bleach and a 2 or 3 boxes of 20 Mule Team Borax (laundry aisle).
    Then, test and repost the numbers. (Do this asap. Your pH appears to be critically low and can damage your pool and equipment! Any reading below 7.0 is acidic. So...... get off to Walmart!)
    Jun 2014
    Las Vegas
    Thanks! Wife's on her way to Wally World!
    Jun 2014
    Las Vegas
    Here are the chlorine and pH numbers:
    Cholrine - Totaly Clear so I guess that's a zero.
    Ph - 7.8
    Still trying to figure out how to conduct the other tests.
    Jun 2014
    Las Vegas
    Here's latest update on tests. Please note my CYA question:
    TH - 340 (wasn't red, more like purple prior to adding hardness titrant)
    Ph - 7.5 - 7.8
    TA - 150
    CYA - Not sure I'm reading this test right. It's asking me to add 7 ml of the cyanuric acid reagent to 7ml pool water. 7 ml of acid reagent is 1/3 of the total amount that came with my kit)
    Since this is a new fill, you won't have any CYA in there yet unless you have used some trichlor pucks, dichlor shock or have added any CYA separately. I assume you have used none of those?
    What exactly have you added to the pool by the way -- ingredients, please? When did you fill it?
    (Do you see now why we call them 'guess-strips'? )
    Jun 2014
    Las Vegas
    Partially filled 5 days ago, finished filling last night. Added about 3 to 4 cups of bleach since initial fill and 120 lbs of salt, that's it.
    Just checked my salt level (using strip LOL) and I'm sitting at 2,860.
