Thread: Pool emergency -- the water turned brownish black!
    Jun 2014
    MN
    Default Pool emergency -- the water turned brownish black!
    I have a brand new 24 ft above ground pool. I have been slowly adding muriatic acids. Once that level was ok alkalinity 194, I added one gallon of bleach, per the BBB method described. Within a few hours, the water turned brownish black! Help! My test strip (I've ordered the drops, just have dip strip for now) still shows low chlorine. What do I do? It was perfectly clear before I put any bleach in it.
    Default Re: Pool emergency!
    . . . membership updated.
    "Brownish-black" is a color I've only ever seen when pools were filled with well water containing manganese -- it's rather difficult to deal with.
  1. Pool water turned green after shocking. How to clear it??
    By aces3 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-29-2013, 09:56 AM
  2. Pool Water Turned Green After Adding Shock
    By tdoss in forum Dealing with Algae & Slime
    Last Post: 08-14-2012, 07:03 PM
  3. My Pool Water Turned Cloudy After Adding Bleach
    By Wraypau in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-19-2012, 11:43 PM
  4. Think I've turned my pool water into bleach!!! Any serious suggestions?
    By dancingfowl in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 01-02-2012, 02:36 PM
  5. Help!!! My water is Black and liner looks black & burned
    By Gwendolyn in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-29-2007, 10:41 PM
