Hi,
I have an intex pool, 18' round. I filled up the pool almost 2 weeks ago, and the water was and still is green. I even got my water tested and the clerk couldn't tell me why. Here's all e info. The water is free, however it doesn't seem like algae to me. I have one of those test kits where you add 5 drops to test chlorine and ph. The chlorine is an orange color which I've never seen. The ph was high so I added acid which brought it slightly to low so I added soda ash to bring it back. The chlorine eventually got he color back into the yellow color, but with all this change to ph/chlorine levels, it had no effect on the color, better or worse. So then the last two days I started shocking it a lot to see if it could be algae. Again, no change at all in the pool color, even bough the ph and chlorine levels are high. So I went to Leslie's his morning to get it tested. Here are the results:
FC. 5^
TAC. 5^
Ph. 8
Tot ALK. 50
CYA. 20
Calcium. 40
Copper/iron. C 4 = .3
The clerk said other than chlorine and PH being high he doesn't know what could be causing the green. One other thing I should add, when I filled up the pool there was a lot of leaves/dirt in it. I though that was the cause at first but I've vacuumed so much and ran the filter for two weeks I can't imagine that's it. Thanks in advance for any help!
Kevin
