Re: Can't figure out why my water is green
He wanted you to look at the inside of the toilet tank and report on the color of the tank, not the water inside the tank. He is trying to verify if there are any type of metals in your water supply. A stained toilet tank will tell if it does and the type of metal can often be identified by the colors of the stains.
