Results 1 to 10 of 11
Thread: Frustrated!!!!
    Default Re: Frustrated!!!!
    Is your pool green and cloudy or green and clear?
    Don't worry about the calcium hardness test.
    Your pH is good. Keep some chlorine in there. For now, aim for 3-5ppm.
    Don't retest the CYA anymore until about Wed. That will be a full week since you added it so it should all be dissolved by then. Report that reading. If it is still showing lower than 30, we'll have you add a little more CYA.
    Jun 2014
    Ontario, Canada
    It is green and clear, I am hoping that is a good sign. Because is was filled from a well I am assuming it is Iron in the water. I just put a new filter in so hopefully that helps some.
    I plan on ordering some better filters from Amazon and the Taylor K-2006 kit, once I get this under control....right now I don't want to spend anymore unless I can make it work.
    3,300 gal, 14x42 AG soft side pool.
    You probably need to get the K2006 and the better cartridges SO you can make it work.
    I've operated numerous pools that were filled with iron contaminated water. Working out a process that is functional for THAT particular pool always took time. Usually, it wasn't till the 3rd season that I could run them without hiccups.
    Operating a small pool, with undersized filters, that is filled with iron contaminated water is a task with a STEEP learning curve. If you aren't able to be patient and accept that there will be failures this year, as you work it out -- save yourself the pain and money, and bail out now.
    But, if you're going to try to do it, do NOT put off what you need now, to make it easier. Of all the periods when you will want "easier", this is it. Later on, when you HAVE a method for your pool, you'll be able to 'get by' without this or that.
