Results 1 to 8 of 8
Thread: Filled small 10ftx30in Intex pool with well water-now it's yellow green
    Jun 2014
    Michigan
    Default Filled small 10ftx30in Intex pool with well water-now it's yellow green
    Hi- Bought this pool on sale, on a whim, summer fun for the kids. We filled it in a couple hours with the hose using our well water. It started to look cloudy and yellow while filling it so we added a quart of household bleach although it's still cloudy and greenish-yellow. We have heavy iron around here and I'm guessing we're in for a bit more work than we bargained for testing and buying chemicals. Yeah, I suppose I should have researched a bit more
    Since the pool is so small, what's the best way to correct this problem without too much effort?
    Thanks!
    Default Re: Filled small 10ftx30in Intext pool with well water-now it's yellow green
    Do you have a way to fill with water that is not from your well? If so, the fastest way will be to dump and refill. It is really hard to deal with a metals-contaminated pool and these little Intex pools are even harder to clean up than a bigger pool.
    Welcome to the Pool Forum!
    Jun 2014
    Michigan
    Thanks for the quick reply! Unfortunately, we don't have another way to fill it. I'm not sure how we could get our household (softened) water attached to a hose outside? Or even if we could get little trucked in.
    So, it sounds like this is a futile effort huh? Is it at least safe to swim in?
    If your chlorine is between 1 - 5 and your pH is between 7 & 8, it's safe for swimming.
    You can connect a water hose to the COLD WATER side of your washing machine hookup, and fill the pool that way. If you reconnect your WM hose with this:
    Gilmour Brass 2-Way Connector
    then you'll be able to easily refill your pool later.
    You can get a WYE like that at Lowes, but try to get a better brand. They all will be Chinese made, but a US brand like Gilmour will try to enforce quality control, and you do NOT want a junk valve leaking water inside your house. Do NOT get a plastic valve; ONLY brass.
    . . . thread moved into correct section; membership updated.
    Jun 2014
    Michigan
    Smile Re: Filled small 10ftx30in Intex pool with well water-now it's yellow green
    Hooking hose up to the WM connection is the perfect solution. Draining it now, refilling tomorrow! Thank you for the help Pool Forum Pro's!
    10' x 30" Intex.
    Default Re: Filled small 10ftx30in Intex pool with well water-now it's yellow green
    Great!
  1. New Intex pool filled with iron contaminated water
    By trockyh in forum Intex-type Pool Setup & Operations
    Last Post: 07-19-2013, 06:33 PM
  2. New to pools.....Filled intex with well water...shocked turned green!
    By prostreetcamaro in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-10-2013, 11:43 PM
  3. Green water in freshly filled pool -- algae or iron?
    By Priceless in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-30-2013, 10:56 PM
  4. Newbie here! Already filled my intex 15x36 pool with water (Oops!)
    By joolz1226 in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-03-2012, 08:40 PM
  5. New liner filled, green water?
    By szcakes in forum Pool Chemicals & Pool Water Problems
    Last Post: 03-30-2008, 08:33 PM
