Don't get the Tristar or Ecostar -- both are much bigger than you need.
Either the SuperPump or the Maxflow will work, but I'd suggest the SuperPump. The Maxflo is optimized more for fountains and so forth.
By the way, if you do buy from Amazon, please use the links here. PoolForum gets a small commission when you do so, but it doesn't change your price at all. Also, if you buy from Amazon, be ready to install as soon as you get the pump. That way, it can be up and running BEFORE the 30 day Amazon return window expires. You'd still have the Hayward warranty, but it's much easier to return to Amazon. The defect rate on the Hayward products is pretty low (I can't recall ever having to return a Hayward pump, filter or heater for a warranty defect), but it does happen.
Of course, if you buy elsewhere, you can ignore all that.
Good luck!
