Results 1 to 10 of 11
Thread: replacing a 16x32 pool liner
    May 2012
    Canada
    Default Re: replacing a 16x32 pool liner
    I have done this twice. The critical part is measuring for the liner correctly.
    Where are you in Canada? I am in the Caledon, ON area and can help if you are close.
    Jun 2014
    Canada
    I'm Located in the vancouver area . What I want is to find a liner for this pool and then have it installed or perhaps install myself with help from friends etc.....
    May 2012
    Canada
    You should be able to get a liner for about $1500.
    So, whatever you're quoted above $1500 is going to be labour.
    It only takes a few hours to install and another hour or so
    to do the skimmer cutout and the return cutouts
    after the water is within 6 inches or so of the openings.
    As mentioned YouTube should be helpful.
    Of course, there are various thicknesses of liner.
    I think you would want the thickest. I think it's 30 mm.
    Do you have a vermiculite bottom, or is it sand?
    Jun 2014
    Canada
    I'm not sure what the bottom is yet as I was told not to remove the old liner til the new one is here in case its a bottom that could get weathered by rain etc... . Would I be ok to remove the liner as it will help for the measurements etc... ?
    If you unhook it, and then replace it, it should be OK.
    FWIW, I've never seen any data or evidence supporting the idea that thick liners last longer. Liner life is seems to be affected by (a) exposure to sun, (b) pool conditions (holes & washouts can 'kill' a liner), and (c) plasticizer loss (= embrittlement and loss of elasticity).
    I think quality of the vinyl sheet material itself is the big factor. Unfortunately, there doesn't seem to be any way at all to distinguish 'good' sheet from 'average' sheet.
    Almost all liners will last as long as the 'real' part of the liner warranty, so there's no help there, either. One AG builder here prefers thin cheap liners and thinks they usually last as long as thick expensive ones, providing the surfaces under the liner are intact.
    Buying from a known vendor (one with a REAL location) and a 10+ year history of selling liners might be your best bet.
    Jun 2011
    I just had the liner replaced by a guy I trust. We selected a design in 27 gauge thickness from Pegasus liners, which is a local company in New Jersey. My pool is 20x40 but otherwise looks almost exactly like yours. We had to make a rush job to be ready for the Princess's graduation party, so I paid a bit extra to expedite the manufacture in a few days instead of a few weeks. But it worked out well. Total cost all in was around $2800.
    We pumped out the old water in about 3 hours, and then a team of three guys took the better part of the day to remove the old liner, patch the vermiculite base with fast-set material, then install the new liner.
    Next, we turned on the hose and began to fill. It was taking so long, I hired a water company to truck in a load of water, which ran another $300. But again, I couldn't wait a week for the garden hose to dribble in 30,000+ gallons.
    I did inquire as to the difference between 27 and 30 gauge thickness and my guy said it wasn't worth the cost differential. He installs about 50 liners each season, so I took his advice.
  1. Replacing deck & coping on a vinyl liner pool
    By sampeterson18 in forum In-Ground Pool Construction and Repair
    Last Post: 06-22-2014, 11:22 PM
  2. Starting up 16x32 AG pool
    By Portland user in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-06-2014, 01:37 PM
  3. Draining and replacing vinyl liner swimming pool water
    By ross_badger in forum In-Ground Pool Construction and Repair
    Last Post: 05-09-2014, 08:40 PM
  4. Replacing a liner in a 16x32' inground pool
    By DIYLINER in forum In-Ground Pool Construction and Repair
    Last Post: 08-23-2012, 07:42 PM
  5. replacing vinyl liner / pool construction questions
    By MissAlabama in forum In-Ground Pool Construction and Repair
    Last Post: 05-31-2010, 11:51 PM
