Re: replacing a 16x32 pool liner
If you unhook it, and then replace it, it should be OK.
FWIW, I've never seen any data or evidence supporting the idea that thick liners last longer. Liner life is seems to be affected by (a) exposure to sun, (b) pool conditions (holes & washouts can 'kill' a liner), and (c) plasticizer loss (= embrittlement and loss of elasticity).
I think quality of the vinyl sheet material itself is the big factor. Unfortunately, there doesn't seem to be any way at all to distinguish 'good' sheet from 'average' sheet.
Almost all liners will last as long as the 'real' part of the liner warranty, so there's no help there, either. One AG builder here prefers thin cheap liners and thinks they usually last as long as thick expensive ones, providing the surfaces under the liner are intact.
Buying from a known vendor (one with a REAL location) and a 10+ year history of selling liners might be your best bet.
