Results 1 to 10 of 21
Thread: Pink "Stuff"
    Default Re: Pink "Stuff"
    This product
    CLOROX Pool Phosphate Remover 1 Quart removes 2,000 ppb (2 ppm) of PO4 from 10,000 gallons. That's usually less than 1/2 what Phos-free does costs, per unit of phosphate removed. It seems to be slow acting, so if you test immediately, you won't see much reduction.
    WRONG: Turns out the Clorox phosphate remover is a seriously bad deal. A quart of the Kem-Tek predecessor product was labeled as removing 2 ppm PO4 from 10K gallons; the Clorox product is virtually the same price, but only removes 0.75 ppm from 10K gallons.
    That means the Clorox product is actually 267% more expensive!
    The Orenda PR-10000 product removes 5x that (10 ppm per 10k gal) per quart, so if you purchase it for less than $70/quart it's even cheaper. But you have to be careful with it, or it will cloud your pool.
    Jun 2014
    Florida
    Default
    Ok. Got test kit and tested CYA. Based on the test my CYA is about 130. The black dot disappeared and the water level is below the letters CYA on the test bottle and based on scale it appears to be in the 130-150 range.
    FC = 2.4 [12 drops x .2]
    CC = 0.40 [2 drops x .2]
    Additional tests
    ph = 7.4
    ALK = 170
    Ch = 460
    You need to take your chlorine level to 30 ppm (20% of your CYA level). You can still swim with chlorine at 20%; I have a 200,000 gal country club pool that's been doing just that for the last couple of days -- no complaints, no problem, no one even notices.
    I wouldn't use any more cal-hypo. Your CH is getting too high. Just use bleach. (Plain, unscented generic Walmart 8.25% bleach is fine.)
    If one scoop of the DPD powder turns the sample pink, no need to use a second scoop. Also, to make your testing reagents last longer, just use a 10mL sample of water and multiply the drop count by 0.5 instead of 0.2. Especially since you are going to have to run such high chlorine levels, you're going to go through the reagents fast. You can also use a 5mL sample, and multiply the drop count by 1. That would make them last even longer.
    Jun 2014
    Florida
    Thanks for all the info. Would it be best to drain off some water to lower the CYA to 30-60 as per the pool builder instructions. Their initial instructions state that "adjustment to alkalinity or partial drainage of pool may be required should stabilizer exceed 60." Tonight's test results: CYA 125, FC 5.0, CC .04, PH 7.4, TA 150, CH 450 with a saturation index of .40. If it matters, the pool is 18 yrs old and it is time to redo the marcite. A friend of mine who has maintained pools for decades at his motels, said he paints them instead of re-plaster. Any thoughts on this.
    Thanks again for your help.
    Lowering the CYA won't help you get rid of the pink algae; you'll still have to run 20+% chlorine level, just readjusted to whatever the new CYA level is.
    Lowering phosphates (<0.100 ppm) and raising borates (>60 ppm) will probably help you get rid of the pink algae, and will definitely make it easier to avoid other forms of algae (green, mustard, black). Given that porous marcite is particularly prone to both mustard and black algae, that might be good idea.
    Painting? I wouldn't if you can wait for the marcite. Ask your friend how often he repaints pools . . . and make sure you want to get on that treadmill before you do so. Keep in mind that painting makes resurfacing considerably more difficult, since every trace of the paint has to be removed.
    Jun 2014
    Florida
    I Apologize for my ignorance but what is this about "borates". How do I test and what is used to adjust? First time I have heard about this. What causes the CYA to get so high, the tablets [trichor-triaz..] or the Power Powder Pro [Cal-hypo-73%]. Thanks again.
    Jun 2014
    Florida
    Yes, great idea. I really don't want to have the high chlorine and based on my other posts it seems like I need to take out some water and replace.
    Jun 2014
    Florida
    I purchased the Clorox Pool and Spa Phosphate remover quart bottle for $17 on amazon. Per chart to remove 250 ppb from 10k pool requires 1/2 the bottle. [$8.50]. Not sure how that compares to the other products. Have been using Phos-free which is about 50-60 bucks per 3 quart jug.
    screened 23.2k gal rectangular 17 x 38 gunite IG pool, depth 4 - 8.5 ft, American Eclipse sand filter, new sand, Hayward EcoStar VS pump. PF=5
    It compares badly.
    I got 20 quarts yesterday and was massively disappointed to see the dose ratings. I'd assumed that they were the same as the Kem-Tek product, but they are not. I've got calls in at KIK (makes Kem-Tek and the Clorox brand products) to see what's going on, but haven't heard back yet.
