Re: Still very cloudy after running filter 24/7 for 2 1/2 weeks, 3rd year using BBB m
Thank you! Here's an update. Still cloudy. I've been keeping the chlorine up, it's sort of like a blueish green mix and less milky cloudy if that makes sense. I can see the bottom now pretty much all the way across, but not easily. I have not used any polyquat yet. I'm wondering if when my filter had a crack in the pipe leading to the laterals (now fixed about 2 or 3 weeks ago), did it cause sand to go into my pool and that's part of the cloudiness problem? When I stir the water up really well I do then notice sand in the skimmer sock. Is there any way to get the sand out other than turning the filter off so the sand possibly settles and then vacuum it out or is that the solution?
9.2k gal 15 x 30 oval AG pool, well water, Hayward S180T sand filter, Astral pump running 24/7. PF=13
