Thread: Just getting started in St. Louis
    Jun 2014
    St. Louis, MO
    Default Just getting started in St. Louis
    Hello from St. Louis! Checking if there was anyone else out there from STL? We live on 26 acres and have plenty of space for a pool. Looking forward to researching on here about it.
    Default Re: Just getting started in St. Louis
    Nope, not from St. Louis, but just wanted to say hi and welcome you to the Pool Forum!
    You can use this link (http://pool9.net/search/) to search with. It will search the entire forum plus our sister website www.poolsolutions.com.
    Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
    Just got through suggesting this to someone else. You may want to consider buying an Intex pool THIS year. You can enjoy it now, learn to manage your pool water, and discover what you really like.
    You may end up keeping the Intex, but if not you can probably Craigslist it a year or two later for 50%, if you get a larger Ultra pool:
    Intex 32-Foot by 16-Foot by 52-Inch Rectangular Ultra Frame Pool
    If you do, two key points:
    1. The pool site needs to be LEVEL, not nearly level.
    2. Prep the site 100% and THEN buy the pool from Walmart or Amazon or someone else that will give you a 30-day return. Intex does honor warranties, but slo-o-owly.
    If you're ready to install the pool as soon as it arrives, you'll be able to exchange it if there's a problem (maybe 5% of the pools) rather than wrestling with Intex.
  1. Any St. Louis pool owners having a lot of evaporation? Or do I have a leak?
    By poolgal13 in forum In-Ground Pool Construction and Repair
    Last Post: 08-11-2013, 09:17 AM
  2. Getting started
    By Lowdown in forum In-Ground Pool Construction and Repair
    Last Post: 10-26-2011, 09:16 AM
  3. New AG pool owner in St. Louis area
    By shovelrog in forum Above-Ground Pool Construction & Repair
    Last Post: 08-14-2011, 10:10 PM
  4. Pool Quote in St. Louis
    By jklym in forum In-Ground Pool Construction and Repair
    Last Post: 08-22-2006, 09:22 PM
