Thread: Chlorine advice
    Jun 2014
    NY
    Default Chlorine advice
    Stumbled upon this site looking for solutions to our problem of our pool not being able to hold chlorine for the last couple of years. Has been a very frustrating, expensive 2 seasons. After reading some of the posts on this site, I think I am starting to find a solution. I have a 27' round, heated (to about 83 deg., above ground pool w/a sand filter. It holds 17,500 gls. After ruling out phosphates, I decided to try the one thing we haven't, dumping massive amts of chlorine into our pool. Also learned that this should be done at night & not in the day, which I didn't know. Anyway, after dumping 10 gls on store bleach in pool, we held chlorine for one whole day. Dumped 10 more gls in pool which held for 2 days. dumped 10 more gls in pool which held for 3 days. Last night I put 6 more gls in & haven't taken a reading yet. We did get a sample tested before dumping in the last 6 gls tho. FC .2, TC .2, CC 0,PH 8 Total Alk Inpute 120 (ppm the rest of these) Total ALk Adjusted 101, Calcium hardness 231, cyanuri acide 58, cooper, iron, manganese, nitrates, total dissolved solid all zero. phosphates ppb 0, sat index .6 endure (?) 0. Haven't been putting the 3" chor tablets either through this process. Am I on the right tract w/what I am doing or not? I think they gave my husb. some shock to put in , which I told him to hold off on & they also gave him some ph decreaser which I'm not sure if he put in yet. The water looks clear & beautiful.
    Default Re: Chlorine advice
    You are on the right track.
    But, instead of having a pool store test for you, it is better and likely to be more accurate, if you do the testing yourself. The test kit that we think is by far the best is the Taylor K2006 or 2006C (better buy). Not available locally but you can get it through this link that takes you to Amazon: http://pool9.net/tk/
    But, in the meantime, go to Walmart and see if they have the HTH 6-Way drops-based kit (no test strips!) and get that. If they don't, get an OTO/Phenol Red kit (yellow and red drops) instead. Use it to test and then post your numbers. Then someone here can better advise you on next steps to take.
    Also, tell us what size of pump you have and what size your sand filter you have.
    Welcome to the Pool Forum!
    Jun 2014
    NY
    Ok, will do, thank you!!
    You're welcome!
    . . . membership upgraded.
  1. chlorine feeder advice
    By nyhcbri in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-18-2011, 06:03 PM
  2. Advice on Chlorine generator
    By Sean-NJ in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-27-2006, 05:56 PM
  3. New to Chlorine, was in baquacil hell, any advice please
    By coadysmom in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-27-2006, 03:06 PM
  4. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  5. Very High Chlorine, Advice Please?
    By DebPoolClueless in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-14-2006, 12:11 AM
