Results 1 to 10 of 16
Thread: Help Sizing and Selecting Natural Gas Heater for AGP
    Oct 2013
    Rhode Island
    Default Re: Help Sizing and Selecting Natural Gas Heater for AGP
    Thanks BigDave. I had considered a heat pump, but I do not believe I will be able to recover from 58 degree June nights for pool use during the day. m I wrong about this?
    Sharkline Escalade RTR 24' x 54" Round AGP; OptiFlo 2-speed pump; Pentair PLM-100 Cartridge Filter; Hayward 250FDN Heater; Taylor K-2006; AquaIlluminator Return
    May 2014
    Florida
    Hi bottomcat I would suggest a 150,000 BTU heater for your application as this size unit would give you a 30 degree temperature rise. The unit I like is the Raypak 014784 heater, this is a 150,000 BTU unit and in my experience has been very reliable. I would also highly recommend using a solar blanket when your pool is not in use as evaporation accounts for nearly 70% of the heat loss in your pool.
    Inyopools
    Oct 2013
    Rhode Island
    Thanks patrick3229. Do you know the efficiency and dB level of this unit?
    BigDave's Avatar
    I've seen heat pump claims to operate down to 50F.
    I agree about the thermal blanket, It makes a huge difference in my pool with solar panels.
    Oct 2013
    Rhode Island
    BigDave, I have also seen that they will operate at fairly low temperatures, but that they simply are not capable of bringing the water up substantially over a reasonable time frame. What are you using there in New Jersey besides the solar panels? How long is your swim season?
    Anyone else have any heaters that they have been happy with or ones that have been poor?
    May 2014
    Florida
    The efficiency rating on that Raypak heater is 82% unfortunately I do not have dB rating.
    In regards to the heat pumps.... Heat pumps draw in the outside air to heat the water so as the outside temperature drops the efficiency and effectiveness of the heat pump drops, typically all of the performance data on the heat pumps is set at an outside temperature of 82 degrees. So even if the unit can work at the lower temperature they will be far less efficient then when operating at warmer temperatures.
    Inyopools
    Oct 2013
    Rhode Island
    patrick3229, I agree. I love the idea of a heat pump (and hate the idea of paying a big gas bill) but with the money already invested in the pool and deck, I want it to be comfy!
    What factors contribute towards reliability in your opinion?
    BigDave's Avatar
    @bottomcat: how do you expect to use the pool / heater when the weather turns chilly? Are you thinking you'll heat it when you want to swim or keep it warm so it'll be ready when you are?
    Me, I don't open until until memorial day because of the pollen and pods. The swim season is pretty much over when the kids return to school school after Labor Day. Maybe, if the weather is with us we can sneak a dip for a week or two after school starts.
    Oct 2013
    Rhode Island
    @BigDave: I'm not really sure. I guess a combination of both. When the kids are home from school, I'll probably set it to stay at 75 or so and leave it on 24/7 for a few weeks at least. If we get busy doing other things, then maybe I'd just turn it on the night before a swim day. It will depend on how much it ends up costing to heat.
    May 2014
    Florida
    In regards to this question "What factors contribute towards reliability in your opinion?" I would say the manufacture actually making the heater we have dealt with all of the major heater manufactures and we have had very little warranty issues with Raypak and Hayward. I tend to like Raypak a little more as that is all they do is pool heaters and nothing else so they are very focused on this product line.
    As far as specific features for reliability you may consider a Cupro Nickel heat exchanger. The main component of a gas heater and by far the most expensive part if it needs to be replaced is the heat exchanger. Most heaters come standard with a copper heat exchanger however you can typically upgrade for a few hundred dollars more to a Cupro Nickel heat exchanger which is a heavy duty heat exchanger which holds up better against your pools chemically treated water, this is a good option if you have a salt pool as well.
    Inyopools
