Results 1 to 10 of 11
Thread: Taking Over Care for a Pool - Need Help
    Jun 2014
    MO
    Default Re: Taking Over Care for a Pool - Need Help
    Here are my results from the HTH 6-Way drops-based kit
    Chlorine - trace amounts if any
    Ph - between 7.2 and 7.5
    Total Alkalinity - took nine drops to turn water color
    Total hardness - initial water color was lavendar/purplish.Took 19 drops to turn blue
    Cya - 55ppm
    Just cleaned the filter and the droid. Added 3 121-oz bottles of bleach as recommended. Do I need to do anything with the 20 Mule Team Borax?
    Jun 2014
    MO
    Also, I assume it is not advisable to swim with the bleach in the pool?
    Your pH is fine. Anywhere between 7-8 is ok, so you don't need the Borax for now. It is used to raise pH. Put it on a shelf and keep it dry and you'll have it if you need it. A note about pH: With the 6-way kit, you will not get an accurate pH reading if the chlorine is higher than 5ppm. With the K2006 kit, the pH test is accurate with chlorine readings up to 10ppm. So, any time that you need to test your pH when your chlorine is higher than these values, you'll have to dilute your sample first by taking 1/4 cup of pool water and mixing it with 1/4 cup of distilled water. Then, test that mix in the normal manner.
    On the TA and CH tests, you multiply the number of drops by 10. So, your TA is 90 which is good and your CH is 190 which is also fine.
    (By the way, I forgot to ask before, is your pool vinyl or fiberglass or gunite?)
    CYA of 55 is great right where it is so don't use any stabilized forms of chlorine which will cause it to go higher. (No dichlor shock nor trichlor pucks.) Now that we know your CYA level, it will help us to better be able to advise you as to how high you need to shock your pool. Take a look at the chart at this link that explains the relationship between CYA and Chlorine:> http://pool9.net/cl-cya/
    (Don't test your CYA anymore at this point. No need to as it doesn't change unless something with CYA in it is added and you'll just be wasting test reagents.)
    So, this evening when you test, you'll want to add enough bleach to take your chlorine up to 15ppm. For reference and to help you figure out needed doses, in your pool, each quart of 8.25% bleach will add about 1ppm and each of the 121-oz jugs will add about 4ppm. You'll want to continue to keep your chlorine at shock level until you meet three criteria:
    1) You lose no more than 1ppm of chlorine from sundown one evening to within an hour or so of sunrise the next morning
    2) You have no greater than 0.5ppm of CC. (Your 6-way kit can't test this, but your K2006 kit will be able to.)
    3) Your pool is clear
    At that point, we typically recommend keeping the chlorine high for one additional day for added insurance and then let it drift down and turn on your SWCG.
    It is perfectly fine to swim with bleach in the pool. It is nothing more than chlorine. In fact, many of us (me included) use nothing but bleach for our source of chlorine. But, with chlorine at shock levels, you'll probably want to wear an old suit.
    So, test pH and chlorine daily. Keep the chlorine high for now, brush the pool while the chlorine is high and run your pump 24/7 while you are working to clear the pool and clean your filter as needed.
    You don't need to test TA and CH daily. Maybe test TA once every couple of weeks unless you notice your pH wandering around and test CH only if you use any cal-hypo or add any calcium. (Unless this is a gunite pool, don't. Only gunite pools need to maintain a calcium level. On vinyl and fiberglass, as long as the CH is not too high, you are fine.)
    A link that may be helpful which shows how to interpret chlorine readings that are higher than the OTO chlorine tester can differentiate. http://pool9.net/oto-chart/
    (Your K2006 will be able to read chlorine readings way higher than 5ppm which is the limit on an OTO test kit.)
    Keep us posted on your progress and let us know if you have more questions.
    (Remember to copy and paste links after you log out until your registration is completed.)
    EDIT --- Just remembered ------ check your manual for your SWCG. Some of them have a required CYA level that you need in order for the unit to operate properly. So, it may be that you need your CYA level a little higher than 55. Let us know and we'll help you raise it if need be.
    Jun 2014
    MO
    Great! Thank you for the help so far. I just checked the pool after adding the bleach around 11am CT and the color of the pool went from cloudy dark green to cloudy light blue. Chlorine levels are currently above 10ppm.
    Bought some extra bleach just in case for later.
    IG pool, C800 Star Clear cartridge filter
    Good deal. Test the chlorine again this evening and add enough bleach to shock it back up!
