Re: Returning Member who has forgotten more than once knew about pools.
Hello Watermom,
I've been registered under two previous names hens1528 and CarolH50; quite a few years ago. I had pools and/hot tubs a couple of times over the years. Then due to health issues I had to give up playing in pools, etc for a number of years, but am once again back into it. Probably more because I want my grandkids to learn the pleasures of it and how to be safe around it.
Thank you for the links to the SSS Recipe and the link to d/l BleachCalc. I read the SSRecipe (really helped a lot to have that refresher; amazing how much one can forget). So far I've not had any luck d/l Bleach calc. I keep getting an error msg: "Unexpected error" every time I try to save and/or run it. I've tried copy/pasting the link into a new tab, window; d/l it when logged out and in; from firefox and IE. Read somewhere on here that someone got it to work by using Chrome so I will try that when I log off here and hopefully that will work. I've tried changing Compatibility settings to it and running as an administrator, also with no success. I'm guessing it's got to have something to do with Windows 8.1 but so far none of the compatibility settings have helped. You wouldn't happen to have a copy you could email me by chance? or any other suggestions I can try. I *think* my Registration is complete. I rec'd the activation email yesterday and went to the link included. That program was soooo very helpful with my previous pools.
TIA
TealMama
