Thread: Bucket Testing
    Jun 2014
    Illinois
    Default Bucket Testing
    Hello I'm new to the Forum and have an unique problem with chlorine demand. Specifically I have not yet put enough chlorine in to get the FC high enough for long enough to hold a FC reading that is needed. I thought by knowing the pool volume and CYA, CC, PH levels I should be able to properly shock the pool. This unfortunately has not been true. I think "knowing" exactly what the demand will be is the next step. What is needed to perform a bucket test and how to do it ? The pool's water has an offensive odor and is crystal clear. All of the readings are in range except the chlorine. My pool is a 14000 gallon in-ground octagon with a vinyl liner. I winterized with a new cover and did not open the pool as early as normal. (first week of June) When I opened it, it was a swamp. What type of chlorine would you use to solve this problem ?
    Hope you can help me solve the problem, Thanks.
    B Helgason
    Default Re: Bucket Testing
    Any idea what your CYA was when you closed the pool last fall? My guess is that your CYA has biodegraded over the winter and created a lot of ammonia as a byproduct. This causes a huge chlorine demand. We see this scenario all the time, unfortunately.
    Directions for doing the bucket test are here:> http://pool9.net/bucket-demand
    Your best bet is to just use bleach as your source of chlorine. Walmart's generic 8.25% bleach is fine.
    What kind of test kit do you use?
    Welcome to the Pool Forum!
    (Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
    . . . membership updated.
    Chlorine demand test => http://pool9.net/bucket-demand/
  1. Buying big bucket of CYA or just as much as you need.
    By Gretzky99 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 10-15-2014, 09:03 AM
  2. Bucket testing for chlorine demand
    By PoolDoc in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-18-2012, 07:23 PM
  3. Bucket test for metals
    By PoolDoc in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-17-2012, 06:58 PM
  4. Detecting a leak with the 'bucket test'
    By Watermom in forum In-Ground Pool Construction and Repair
    Last Post: 05-21-2011, 10:57 PM
  5. Mystery bucket of chemical - what is it?
    By aquarium in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2006, 01:37 PM
