Thread: Too Much Chlorine in My Little Intex
    Jun 2014
    Ventura, CA
    Default Too Much Chlorine in My Little Intex
    Hi all. Glad to have found the forum here. I set up my first pool ever (8' intex vinyl), and after having my tap water tested the first day I had the following:
    FC 1.5
    TC 1.5
    CH 150
    CYA 0
    TA 150
    PH 7.7
    Phos 300
    At that time I purchased a Chlorine and PH test kit from Leslie
    I added 1.4 oz of Muriatic acid last night to work on the TA
    Retested today and had TC levels near 0 according to my kit, and PH at 7.5
    I decided to add chlorine and used poolcaclulator to figure out the amount, however when I put my new stats in I neglected to change the pool size from 10000 gal to 640 gal.
    I added 18 oz of bleach (way too much) instead of 2 oz.
    now my chlorine levels are 10+
    How long will I need to wait for levels to drop down naturally to safe levels, or am I just better draining partially/full and starting over.
    Thanks a ton!
    Default Re: Too Much Chlorine in My Little Intex
    With no CYA in the water, it won't be long. Don't worry.
    An easy way to start up a freshly filled pool is with our Super Simple Start-up Recipe. Read about it here:> http://pool9.net/ssr/
    Welcome to the Pool Forum!
    (Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
    . . . membership updated.
    To be a little more specific -- just a few hours of full sun will take your chlorine back down to zero.
  1. Chlorine question for Intex 22'x 52" pool
    By Jewlz in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-26-2014, 03:12 PM
  2. Intex SWG - high salt no chlorine - HELP PLEASE
    By tarheelwood in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-19-2014, 06:58 PM
  3. no chlorine in Intex w SWCG
    By slingblade in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-18-2013, 08:57 PM
  4. Intex SWG How much chlorine?
    By posguy in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-05-2013, 03:28 PM
