Results 1 to 10 of 36
Thread: Cannot maintain FC levels w/ BBB
    BigDave's Avatar
    Default Re: Cannot maintain FC levels w/ BBB
    Usually chlorine consumption goes down with high CYA. I wonder if you don't have an algae bloom trying to start. Do you have the K-2006? Do you have a CC level?
    The overnight test is definitive for chlorine demand. Measure FC and CC in the evening close to sunset. Repeat the FC and CC tests the next morning close to sunrise. If you have CC or you lose more than 1 ppm FC overnight, there's something in the pool being oxidised.
    Last edited by BigDave; 06-27-2014 at 04:24 PM. Reason: Fix Spelling - "consuprion" - sheesh!
    Apr 2014
    Slatington, PA
    Thanks Big Dave.
    There is a bit of green spotting on the liner so that could be it.
    Yes we have the K-2006 kit and I will have my wife check for CC tonight. I know that it should be at 0, but what should I do if it is higher? Shock the pool?
    Thanks again!
