Re: Cannot maintain FC levels w/ BBB
Dave and I were apparently posting at the same time, but you see that the advice is the same.
Also, brush the pool while the chlorine is high and run the pump 24/7 while you are working on this.
Thank you Watermom.
We are going to a baseball game tonight, but I will have my wife shock the pool and we will test late tonight.
Thank you all!
BTW, can my daughter swim if the pool is at 20 FC?
With a CYA of 90, sure. Wear an old suit.
Yes, but she will probably want to wear on old swimsuit that she won't care if it fades some.
Great. Thanks again. I love this site!
Good morning.
My wife checked the FC level at 6pm last night and it was 7.8. She said the tested water only turned a very light shade of pink when adding the 5 drops of R-0003. That indicated to her that the CC level was near 0. She added (3) 121 oz jugs of 8.25% bleach. When I got home at 11pm I tested and the FC was 20, and similar to my wifes testing of the CC, the water only turned the absolute slightest shade of pink, so I added 1 drop of the R-0871 and it became colorless. This indicates to me that the CC is near 0. This morning at 7:30 I tested again. The FC was at 18 and the CC was similar to the night before.
So it looks like I lost ~ 2 ppm of FC (assuming a slightly incorrect reading as I tested a couple hours after sunrise).
I did not have a chance to scrub the floor and walls as Watermom suggested and there are small areas of brownish, greenish, yellowish patches sporadically on the pool floor.
What do you guys think?
Thanks PoolDoc.
Watermom,
No offense taken at all. As mentioned, this site and the replies to my issue have been a great experience so far. I am leaving again for the evening so I added 2 gallons of 8.25% bleach. My FC was down to 13.8 this evening (No CC) from the 18 I measured this morning.
I'll test when I get home tonight and again in the AM.
I hope this stabilizes soon!
Thanks again.
So I added (2) gallons of 8.25% bleach at 6pm on 6/28 when the FC was at 13.8. I got home at 10pm and the FC was 18. I checked at 6am the next morning and it was at 17. I did not add anything all day yesterday and checked the FC at sundown last night (~ 8:15pm) and the FC was at 12. It lost 5 ppm of FC all day. I checked again this morning at 6am and it was at 10, so it lost 2 ppm overnight. I added (2) gallons this morning hoping to get it up to close to 20 again for the day.
The CC is reading 0, so I am a bit confused as to what I am to do next. The pool is taking at least (1) gallon per day to "maintain" FC level.
Any additional help would be appreciated.
