I'm sorry, but I need to warn you again: clearing a Summer Escapes or Intex pool, once algae has formed, is a SLOW process, more likely to take weeks than days. That's why I encouraged you to drain and refill.
The Unicel cartridges will help, but not make it a speedy process.
Back to the pool: if your pool is STILL green, you need higher chlorine levels. Without knowing your CYA level (for which you have to have either a K2006 or an HTH 6-way drops kit), I can't say how much higher.
I hope you are using an OTO drops kit -- if not, you need to be. Keep raising the chlorine till you get into the OTO orange range. Once the algae finally dies (turns gray), brush the pool completely and HOLD the chlorine level at whatever it is then for several days. Then you can begin letting it drop.
At that point, if you want to add a clarifier it will likely speed the process somewhat. Chem_Geek has done some testing with different products, and has reported that the BioGuard Polysheen and the GLB Clear Blue work best. But, do NOT overdose -- doing so will actually make things WORSE, not better.
Be SURE to rotate your Unicels in and out, after cleaning them properly: http://pool9.net/cart-clean.
You can swim, once the algae is dead. But if the chlorine is still in the orange range, wear old suits: high chlorine will damage them; people are far, far more resistant than swimwear!
And, be patient -- it WILL be a slow and frustrating process.
There is a faster way, using floc, but it's tricky, and requires that you have the equipment to vacuum to waste (out of the pool and on to the ground).
Good luck!
