Thread: New to the neighborhood...
    Default
    You can keep the pump . . . provided you always, or almost always, run on low speed. Use high ONLY when you are cleaning, draining, or something similar.
    Note the change in gallons: pool volume is water depth, not pool depth. (I assumed that the 4' dimension was the pool depth, and not actual water depth.)
    Forgot about the suction leak! Read http://pool9.net/leak-s/
    Jul 2014
    Default Re: New to the neighborhood...
    Yes, that is what I was hoping/planning. At the moment, the speed selection is by flipping a switch, but I am, after all, retired..
    And I reset the change - I did measure the actual water depth. There is about 10" of pool above the water level.
    Thanks - after reading that article, I found that there were a couple of threaded connections that were leaking - a bit of Teflon tape seems to have helped quite a bit. I suspect that I will find that there are other contributing factors, but this is at least a start.
    7900 gal 24'x11'x4'(water depth) Viking fiberglass pool c. ~1965, new 2spd 1.5HP pump, original Nautilus 48 DE filter, Polaris 380.
    Jul 2014
    I replaced the section of inlet pipe between where the inlet pipe comes out of the ground with a short curved piece of 1 1/2" Schedule 40 pipe (from the electrical department - wires seem less tolerant of sharp bends than water). With the new pipe I could take advantage of the 1/2 union that came with the pump (the pump inlet is the other half). The old pipe was composed of short pieces of pipe and 45 degree connectors and a 1 1/2" threaded connector and a a 1 1/2" to 2" threaded adapter, and was probably 10-20 years old, and was badly sun damaged, and the threads on the connectors seem to be worn enough that no amount of Teflon tape would keep it from sucking air.
    Now, when the pump goes on, any air in the input strainer disappears with seconds, and the only air I see is one small bubble quivering in the handle portion of the clear plastic lid.
    And the pool sweep (Polaris 380) seems to be quite happy with the main pump on low speed, so I don't plan to use high speed much.
    Thanks for the help.
    Glad it worked out!
  1. SWG for neighborhood pool??
    By trexok in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-09-2006, 11:40 AM
  2. Gifts from a neighborhood cat
    By Lenny in forum Pools, Pets and Creepy Critters
    Last Post: 06-10-2006, 10:51 PM
