Pentair Superflo model # sf-n1-1a 1 hp pump .....
voltage=115/230
full load amps=14.2/7.1
hp=1
sf=1.25
sfhp=1.25
not sure if any of that helps..? Yes , handy enought to do what needs to be done.
voltage=115/230
hp=1
sf=1.25
sfhp=1.25
OK. That model is the 1hp Up-rate standard efficiency Superflo.Pentair info pageHere's an option:
ManualPentair 350088S with SWTCH SQFL 3/4 HPF 1A 60-Hertz 2SP ALMD Motor PackageCheck the manual, and confirm, but I believe those are the right parts to convert your pump from a standard (low) efficiency 1HP motor to a high efficiency 2spd motor - for around $250.
Pentair 355067 Impeller Assembly Replacement Pool and Spa 1 HP Inground Pump
Seal and gasket kit at A1PoolParts.com
You'll want to run on LOW all the time, except when priming, vacuuming or backwashing. LO moves about 1/2 the water that HI does, but uses about 1/6 the electricity. Your flow will be much better matched to your pump -- and your water may be clearer as a result. Your electric bill should go down a bunch!
A couple of tips:
1. If you have a timer, you may have to put a check valve in the piping just ahead of the pump, so it doesn't loose prime when it's turned off. The Jandy check valve is available from Amazon and is a good choice.
2. You'll need to watch your backwash discharge. If you find sand coming out with the backwash, you'll need to put a valve on the discharge (a cheap PVC ball valve is fine) and throttle it to slow the flow. LO may be too low to fully backwash, but HI may be too high.
PoolDoc / Ben
I'm actually thinking of upgrading to a hayward 24 or 27 inch sand filter...I looked at the 24 inch and it seems to be enough flow to handle the Pentair pump...any thoughts?
Upgrading filters is ALWAYS a good idea. Even so the 2 speed works better with sand filters.
The slower the flow, the better the filtration with sand. 8 hours on LO will produce higher water quality than 4 hours on HI . . . and will use less than 1/2 of the electricity!
With the larger filters, you won't need a discharge throttle valve, but will definitely need to backwash on high.
Another question ...should I plumb the pool with 1 1/2 or 2 " pipe? ....what is the benefit of 2"if any beside less pressure?
Again...thanks for the help
Before I try to answer ?'s like that, complete the pool equipment form: http://pool9.net/pf-equip-form
In the notes, include info about extra equipment, number of skimmers, and number of returns.
PoolDoc / Ben
Form completed.
18.5k gal 27' x 52" AG pool, Pentair SuperFlo 1hp pump; 24" Hayward sand filter, single skimmer & single return, mesh winter cover. PF=7.2
