Re: Need help getting my pool right for birthday party this saturday
i only added the 1 pound of ph minus.
i keep thinking my test kit is a 6 way and its not. it has 6 chemicals but is a 5 kokido 5 way test kit. it test chlorine/bromine/ ph/ acid demand and total alkalinity.
i tested chlorine/bromine, ph and total alkalinity
heres what it says to do and results i got.
fill chlorine bromine cell, add 5 drops OTO-50, match color and ecord as ppm
Results: chlorine 5ppm bromine 10 ppm
ph
fill ph cell to mark, add 5 drops of ph-red, invert and mix, match color and record as ppm
results, ph 7.5 ppm
total alkalinity
fill tube to 25mL add 2 drops of alk-10, add 5 drops of alk-20 water should turn green, then add alk-30 dropwise after each drop count and swirl to mix, until color changes to red. multiply drops of alk-30 by 10 and record as ppm
it took 17 drops of alk-30 x 10 would be 170 ppm total alkalinity. so i guess my kit doesnt do cya?
or is tha the acid test?
