Results 1 to 10 of 114
Thread: Chlorine Lock ?
    Jul 2014
    SC
    Default Re: Chlorine Lock ?
    The FC has been at 19.5 the last three testings but I think somewhere back in this thread, watermom advised to get it to 25ppm and hold and make sure CC less than .5 (the CC was 1.5 this morning), then back off until 10-15ppm and maintain. Ive been adding bleach to get up to the 25ppm but if I am understanding correctly, I can hold it at 19ppm, test every couple of days, and add bleach if necessary. PH 7.6 this am. It is to be sunny, hot and humid here for the week-normal summer. Will that full blown sun on the pool all day make my numbers go haywire again? Hang in there with me! I think I'm starting to "get it". My neighbor told me yesterday my pool was sparkling!
    23k gal vinyl IG rectangular pool, Hayward 1hp pump; Pentair top mount sand filter, 8hr on time, chlorine feeder, K2006. PF=5
    Jun 2014
    Take a look back on the thread. The 25ppm recommendation was for a shock level when you posted a CYA reading of 80. At 130 CYA, you're target numbers become respectfully higher.
    Your numbers are not "haywire" as long you know what they mean and what to do (or not to do). That's when you know you've got it
    19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit. PF=6
    Jul 2014
    SC
    Appreciated. Thanks!
    Sorry to disagree Big Splash, but with a reported CC of 1.5, mjsboone is not in maintenance mode just yet.
    Continue to keep the chlorine at 25ppm and test daily. Keep it at that level until you pass the 3 criteria:
    1) Don't lose more than 1ppm from sundown one evening until within an hour of sunrise the next morning
    2) CC of no higher than 0.5ppm
    3) Water is clear
    Then, keep it high for one additional day and then you can let the chlorine drift down and keep it between 8-15ppm ALL the time.
    Thanks, WaterMom.
    @mjsboone: I just checked your form results, and your pool definitely seems to be improving over the interval you recorded (8/1 - 8/4). In particular, I noticed the gradually diminishing CC levels (3.0, 2.0, 2.0, 1.5, 0.5, 1.5) and the improvement in odor. Both factors suggest you are on the right track, and are close to the 'finish line'.
    Jul 2014
    SC
    Thank you PoolDoc. I will keep testing and posting until everything is square!
