Results 1 to 10 of 114
Thread: Chlorine Lock ?
    Default Re: Chlorine Lock ?
    Brown / yellow dust that turned green when you swept it?
    Jul 2014
    SC
    I would say more greenish brownish-clumpy. It has been over a week since being swept and with the filter pretty much going all the daylight hours, today was the first day that I looked at it very still. There was a lot of junk on the bottom. Pool has not had much use to stir it up. Could I still have algae or even dead algae settled on bottom?
    23k gal vinyl IG rectangular pool, Hayward 1hp pump; Pentair top mount sand filter, 8hr on time, chlorine feeder, K2006. PF=5
    Jul 2014
    SC
    Just went out and looked at pool again. Looks great-clear and sparkly. Could some of that staining disappeared this quickly??? Within the past 2 hours???
    Yes, if the stains were organic, high chlorine can take care of them. Even though your water looks clear, still keep high chlorine until you meet the 3 criteria posted above.
    Jul 2014
    SC
    Noticing some changes in pool this morning and have submitted pool history entries. Would it be possible for Watermom or PoolDoc to take a look?
    Thanks for all your guidance and support!
    Ok, you're reporting what sounds like mustard algae -- so you'll need even higher levels of chlorine.
    BUT . . . I'm puzzled by the difference in readings between what you entered in the form, and what you entered in the notes. For example you entered pH=7.0 in the form, but in the notes you have pH=7.6 .
    Jul 2014
    SC
    I am unable to enter decimal points on the form for some reason. I asked the tech guru in my household and he says that the keyboard that pops up on my tablet from your history form will not let me add symbols. I believe I have been entering the correct numbers with decimal points in the narrative section on pool history form.
