Results 1 to 10 of 114
Thread: Chlorine Lock ?
    Jul 2013
    Northern Illinois
    Default Re: Chlorine Lock ?
    How's it going?
    Jul 2014
    SC
    I have not been able to hold the water at FC 25ppm for overnight. That's where I'm at. I have met 2 of the 3 criteria that Watermom told me to achieve. Hold FC at shock level of 25ppm, CC less than 1 (which I have achieved!) and the water is clear (which is beautifully clear). The FC seems to go down over night by 1-2 ppm. I add more bleach to bring it up and I think I'm ok, then test again in the morning and down it goes. It has been a little frustrating. We have been vacuuming to waste and adding water when needed. Not sure what else to do...
    23k gal vinyl IG rectangular pool, Hayward 1hp pump; Pentair top mount sand filter, 8hr on time, chlorine feeder, K2006. PF=5
    It's only dropping from FC=25 to FC=23 or 24 overnight? Then you are good as gold! If it dropped to FC=10 then you'd still be fighting. But down 1-2ppm from 25? Not to worry!
    Jul 2014
    SC
    After I test at dusk, generally I am at about 21. I add enough bleach to bring it up to 25 and then overnight I go down again when I test in the morning before sun up. I add mor bleach to bring it up again trying to hold that 25ppm as I was advised. It just evades me! PH is 7.4 but I understand that may not be correct because of high FC that I am trying to hold on to.
    If it's only dropping to 21 or higher, you are FINE! If everything else is now good, you can let the chlorine gradually come down to the maintenance level and go swimming!
    Jul 2013
    Northern Illinois
    Thanks, Carl! I had a feeling mjsboone might be struggling out there waiting for input.
    Jul 2014
    SC
    Thanks for the feedback. I appreciate it.
