Thread: Installing Pentair IntelliChlor (salt cell)
    Jul 2014
    Southern California
    Default Installing Pentair IntelliChlor (salt cell)
    I bought a Pentair MasterTemp heater, Pentair Intelliflo Variable Speed Pump, Pentair IntelliChlor Generator Cell and Power Center. Got my estimates to install everything, was way too high for me so I decided to install everything my self. Everything looks great, no leaks, chemicals balanced, etc. Now to turn on the salt cell. In reading the manual the cell must be connected to a timer because it should only be running when the pump is running. I had to redo a lot of the electrical and removed the old timers.
    Can anyone tell me what options I have to connect the salt system to a timer without spending a lot of money?
    Default Re: Installing Pentair IntelliChlor (salt cell)
    1. Wire the SWCG power center with a power cord (25' 14-3 outdoor extension cord, cut to length).
    2. Get an outdoor timer, like this one: Intermatic P1121 Heavy Duty Outdoor Timer 15 Amp
    3. Connect the timer to the power.
    4. Plug the power center into the timer.
    5. Program the timer.
    FWIW, the Intellichlor SWCG cells have a flow switch that will shut them off when the pump is not running.
    Also, Pentair has GUTTED the warranty on self-installed products. If you've got warranty issues settle them ASAP.
    Jul 2014
    Southern California
    Thank You for your quick response. It was helpful. I will be swimming in saltwater tonight.
  1. Pentair intellichlor upgrade
    By Smonahan0129 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-20-2014, 05:17 PM
  2. pentair salt cell
    By bradc344 in forum Pool Equipment & Operations
    Last Post: 04-30-2012, 10:57 AM
  3. Intellichlor by Pentair Cell Light not on and other issues
    By TAS17 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-02-2010, 02:45 AM
  4. IntelliChlor IC20 - Cell Light off more than on
    By CanuckPool in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-27-2006, 01:00 PM
  5. Anyone familar with Pentair IntelliChlor?
    By mshumack in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-26-2006, 02:59 PM
