Results 1 to 10 of 14
Thread: Fanta Sea Help
    Jul 2014
    New York
    Default Fanta Sea Help
    Rebuilding a 26 year old Fanta Sea 16 X 32 5.5 hopper, it has been empty for 5 years and needs to be cleared of many tree roots that have grown on the bottom. Looking for dig spec for the hopper. My original liner and its replacement 10 years ago had a walk ledge of about 1 foot or so around three sides. I called Pool Supplies.com and they sent me a spec that does not have the walk (safety) ledge. Have been trying for a week to re contact them via Email and phone. I get no response to Email and the phone Extension of the person who originally sent the spec goes to voice mail. If I try to speak to another Rep they just transfer me to the voice mail system of the original rep. QUESTION: Do they still make the liner with the walk ledge, and does anyone have a copy of the dig spec?
    Default Re: Fanta Sea Help
    Yeah, the new answering system is a pain in the neck. Took me a while to actually get to one of the support people in Grand Island. Yes, they still make the liners with the safety ledge. There is no reason why they cannot give you the spec. The hopper is the same on three sides, but the angle to the shallow end is longer than the three sides. I am not able to get the spec for the next three weeks, but I have it. But the company should easily be able to get that.
    Again, you have to tell them that you need to talk to technical support, not an account rep.
    Jul 2014
    New York
    Thanks Carl. I'll keep trying. BTW did you or anyone else you know of ever replace walls with anything other than their wood or space age material. Just curious I am thinking of alternate materials to use.
    Quote Originally Posted by TomSINY View Post
    Yes J_Palmer_Cass suggests using 3/4" pressure treated ply, with stainless screws, and lining the inside with pool foam before installing the new liner. If you can find a marine-grade P/T with an A/C side, rather than C/C, that would be better. The wood waterwalls run about $120-130/ sheet but 3/4 P/T ranges from $35-55/ sheet and pool foam is about $50 for a 100' roll, 48" wide. The math is compelling.
    Jul 2014
    New York
    That is the way I was leaning, I also thought I would paint it with a good Marine Paint, or perhaps a 2 part Epoxy, I think sealing the bottom edge (ground Contact) is most important. I did get the dig spec today Just one sheet with 12X24, 16X24, 16X32, 20X40, and 16X48, also was advised that all liners are available with the walk ledge. Thanks for your help, I'll post Pics when finished.
    Fantasea AG
    Jul 2014
    MA
    Have you inspected the upper rail system in detail? I did not do so, and at year 30 (2013) I had an upper rail failure. Liner was at the end of life so at least I did not have to replace a "good" liner. Some details here:
    http://www.poolforum.com/pf2/showthr...Fanta-Sea-Pool
    I did a full rebuild last year due to that failure, so I can give you some advice based on experience if you need it. I have a lot of pictures if you need to see what is involved.
    FantaSea AG pool, 16' x 32' x 4' flat bottom, Hayward T210 sand filter
