Results 1 to 10 of 23
Thread: New Pool Owner
    Jul 2014
    Austintown Ohio
    Default Re: New Pool Owner
    Sorry I haven't posted in the past few days!
    I have been very busy at work :-(
    Good news is I figured out how to easily convert my pool.
    This was purchased from my local pool store
    I also purchased a 1 1/2 pool return fitting and screwed the part above to that. (I did have to carefully cut the opening a bit bigger so I could fit it thru the hole)
    On the skimmer I cut the hose that came with our new pump and just used a hose clap to hold it in place!
    No leaks!
    I hope this helps!
    20' Summer Escapes / Pro Series AG pool
    Jul 2014
    Austintown Ohio
    It's no problem, I hope it helps others, all the Intex "optional" parts were not necessary!
    Jul 2014
    Austintown Ohio
    I am seeing progress!
    It's starting to clear up after 2 days of running the new sand filter!
    Excellent! Chlorine can kill stuff but it is up to good filtration to clear a pool.
    Jul 2014
    Austintown Ohio
    Day 3 - The water is even better today, I can easily see my feet in the pool! I love this new pump!
    Can you post current pictures of your pool, and of the filter and connections?
