Thread: Small-- less than 1000 gallon intex question
    Jul 2014
    IN
    Default Small-- less than 1000 gallon intex question
    Hi. We have an 8 ft intex 696 gallon pop up pool. I have read the simple instructions for 2000 plus gall
    Default Re: Small-- less than 1000 gallon intex question
    Honestly, with that a pool that small, you need to use the SSR -- but drain it every 2 weeks.
    There's simply not enough water to treat it like a regular pool. Put another way, in a pool that small, the 'people goo' becomes too concentrated to deal with the same way. It's more like spa, with a really bad filtration system.
    Get a cheap OTO kit; use the chemicals found in the SSR, add a dose of chlorine every evening. But also add a small dose before, and a regular dose after each time the pool is used.
    Then, drain and refill it every 2 weeks.
  1. Cost of Maintaining 4,400 Gallon Intex Pool
    By ransomedbyfire in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-25-2014, 05:43 PM
  2. 10ft x30 intex pool with 530 gallon filter i need help with HTH chemical please
    By suezy in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-22-2013, 09:43 AM
  3. Is the leslies basic kit a taylor 1000
    By dansdad in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-18-2013, 09:38 PM
  4. small intex 2,000 gallon above ground
    By luvmypool in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-21-2012, 11:26 PM
  5. intex small 8' x30"
    By flprobsolver in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-10-2012, 06:53 PM
