Re: Re-occurring ZOMBIE Algae...
Ben,
Thanks for all the help!
Yes, I understood what the benefits are of Borax and that it most likely would not help the mustard algae. I was looking more toward the "other" benefits; sparkly water, resistance to green algae, etc.
At any rate, the pool was looking good on late last week so I took the plunge. I added one gallon of MA to reduce my PH, and brushed to mix. Then I added the borax and brushed to mix. The next day I tested and my PH was slightly high so I added more MA, and then it was slightly LOW, so I aerated. LOL
My better half had ordered the Intex Krystal Clear Salt System on amazon, and it came on Friday. Picked up four 40lb bags of pool salt and added to the pool on Saturday. We swam most of the afternoon to mix up the salt, and Sunday morning I connected the system and it worked instantly.
The water was a bit cloudy after the salt, but before, it was sparkly. I imagine that might have been a result of the borax because it never was that sparkly before.
At any rate, the pool is a lot clearer this AM, and I'm running the pump 24/7 right now to keep everything mixing. I have the salt system set to run 6 hours, so I will test FC today when I get home.
I also added two pucks in a floater because I know with the salt system my CYA needs to be higher than 40 (that it is now).
So far, so good. The crazy thing is I have seen NO SIGNS of the mustard algae since I did this. So time will tell...
5.2k gal 16' x 48" Summer Escapes AG, Intex 2650 Sand Filter. PF=23
