Results 1 to 10 of 43
Thread: Re-occurring ZOMBIE Algae...
    Default Re: Re-occurring ZOMBIE Algae...
    1. I'd be glad to have the help, BUT I don't want anyone to do it for that reason. If you want to try it, I'll help and collect info. If not, that's fine too. It was only an offer. Once I have a few more "ducks lined up", I'll probably invite participation, but I'm not at that point yet.
    2. Go ahead with borates: it's fairly easy, and fairly cheap for a 5,000 gallon pool (5 boxes of borax + 1 1/4 gallons of 31% muriatic acid). That would be a useful experiment, too. The best info I have at present is that borates help with winterization and green algae, but not so much with mustard algae.
    3. The kits you need are ALL linked from the testkit page: http://pool9.net/tk/
    4. Phosphate remover is problematic. Most of the phosphate removers available are highly diluted and over-priced. The Kem-Tek brand I've recommended on Amazon has morphed into the Clorox brand and is now EXTREMELY diluted. The only desirable product is the Orenda PR-10000, which is not widely available except in large commercial quantities. For now, you'll have to search for it yourself. But I'm looking at some other options.
    BigDave's Avatar
    I bought Kem-Tek phosphate remover yesterday on Amazon. Still in stock now. Maybe I should stock up.
    Make sure it's still the 2 ppm PO4 per 10,000 gallon, rather than the diluted 0.75 ppm/10k gal stuff. The original is a better value than all other products EXCEPT the hard to find Orenda product. The new diluted 'Clorox' blend is a very POOR value.
    BigDave's Avatar
    I'll check in when it arrives tomorrow.
    Jul 2014
    Christmas, FL
    Dang it! I should have check this thread yesterday while I was at home depot! They actually had ONE bottle of KEM-TECH phosphate remover, and it was DUSTY. I imagine it was just what I was looking for. They also had POOL-TIME brand but the packaging boasted about "water clarity" and I was like mmmmmhmmmm you've got something else in you... But, this bottle of KEM-TECH looked very good. It had the amount chart on the back, and did not boast that it contained other additives. I might swing back by there and see if they still have it. It was off on it's own away from all the flashy products. Oh and it was $12, I will check amazon for comparison.
    5.2k gal 16' x 48" Summer Escapes AG, Intex 2650 Sand Filter. PF=23
    Jul 2014
    Christmas, FL
    It was this exact bottle for $12 http://www.amazon.com/Kem-Tek-KTK-50...remover&dpPl=1
    Should I have picked this up???
    Yes, that's the right stuff.
    BigDave's Avatar
    The bottle of Kem-Tek phophate remover I just bought from Amazon is labelled the same as the two I bought in June.
    OK, good.
    If you have a PO4 test kit, I'd be interested to see how much removal you see for a given dose.
    BigDave's Avatar
    The data I have so far is uncomfortably soft. I have the Taylor phosphate kit.
    From the initial supply bought from Amazon in June, I used about (not measured, guessed) one and a half quarts to get from > 1000ppb to 500ppb. At this point, I added 5 days worth of bleach, covered the pool and went on vacation.
    Ten days later I uncovered the pool, FC 12ppm (CYA 60), some appearance of what might be dirt or might be mustard algae in the seams and corners where it usually grows. Allowed FC to come down and maintained 5.5ppm-7.5ppm FC. Added about 1/2 the remainder of the second quart.
    Another ten days or so go by with several thunderstorms bringing tree debris into the pool. Definite return of mustard algae. Brush, vacuum, backflush. PO4 now at 250ppb. No makeup water for the three weeks since PO4 measured 500ppb. Added the remainder of the second quart.
    So, about 8oz of the (June) Kem-Tek phosphate remover took about 250ppb out of my 7700gal pool. If my math is right, that's a whole lot more like 0.75ppm/10,000gal than 2.0ppm/10,000gal as described on the label. This is of course confounded by the storms, debris, high chlorine and time.
