How long ago did you add all of this stuff? I think you are likely going to find out that your overshot your target by quite a bit. Adding 5 lbs. of CYA to a 4800 gallon pool should add about 135ppm!! Don't add that last pound!!
What is the source of your fill water? You might want consider draining almost half of the water and refilling. That would put you at about the target you wanted.
