Results 1 to 10 of 72
Thread: Cannot raise CYA
    QiingGuy is offline Registered+ Thread Analyst QiingGuy 0
    Jun 2014
    Las Vegas
    Default Re: Cannot raise CYA
    A little good news, wife took sample in for test yesterday and my CYA is at 50! Do the experts here think it will continue rising? All of the conditioner in the sock is now gone, has been since the weekend. Reminder, I added the original 2 lbs on June 19, 2014. The follow-up HTC application was done on July 5, 2014.
    I still have the remainder of the HTH conditioner sitting in a 5 gallon bucket on my patio with I'd say 1/2 of it dissolved. I could pour the liquid in and leave the undissolved granules out. I'll wait for advice.
    I tested this morning and I had just under 1 ppm of chlorine. Per instruction I added 1/2 gallon of bleach and ran the pump for 1 hour and tested. It took it up to about 13ppm. I'll test again at 8 hours.
    It's going to be a hot one today, 110 here in Vegas so I'll be looking at worse case scenario I suppose.
    I'd wait a week, and see.
    However, dealer pool tests are generally NOT trustworthy. Unless they used the cloudy water / disappearing dot method (or a spectrophotometric equivalent), that test result may be meaningless. Get a K2006!
    Jun 2014
    Las Vegas
    @PoolDoc - The store she took it to did/does the cloudy water/disappearing dot method. She said he did it twice with the same result.
    I have the test kit, however, it doesn't seem to come with many tests so when convenient I've been taking it in for testing. Last time I tested I got the same reading as store on samples taken at same time.
    I'll wait on adding the additional CYA water.
    OK, that's fine. You're fortunate to have access to a store that does reliable testing!
    Jun 2014
    Per http://www.poolcalculator.com
    34ozs is what gets you to 50 (from zero). If you've added more, expect a higher reading in your next test.
    19.5k gal, 16x32 vinyl liner, sand filter, 1hp single speed pump, K-2006 test kit. PF=6
    Jun 2014
    Las Vegas
    Quote Originally Posted by Big Splash View Post
    Going off of memory here, I've added between 64 and 80 oz. of conditioner, so based on this I should be off the charts by now right? Can it take upwards of 6 weeks for CYA to reach it's peak?
    If you recall, this was my concern back in post #2 above. The amount of CYA you added (your reported adding 5lbs.) should have added approximately 115ppm. Go back and read the beginning of the thread if you need to. But, it should NOT take 6 wks. to be able to be detected.
    I have asked Ben to take the time to read this entire thread if he hasn't yet done so.
    Jun 2014
    Las Vegas
    @Watermom, yes I remember (in-fact I read the entire thread this a.m.). Here's a thought; the first dose I used I put in a 5 gallon bucket for a few hours to dissolve. Maybe I thought more was dissolved than actually was and when I put it in my pump sucked out what wasn't dissolved. That said, when I did my second application using the sock I followed the directions on the back of the HTH container and added recommended amount to raise to my target level.
    Just thinking out loud.
    If you poured the water/CYA from the bucket into your skimmer, it would have finished dissolving in the filter and should still be able to be accounted for. Did you backwash any after you added it via the skimmer? If so, how long after the application?
  1. Should I raise my cya?
    By gmh757 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-25-2014, 11:18 AM
  2. Can't Raise my CYA
    By cooper in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-01-2012, 08:49 PM
  3. Cannot seem to raise Ph
    By D_Case in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-19-2012, 01:45 PM
  4. No CYA - How to raise it?
    By mortimay in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-03-2011, 06:33 PM
