In ground pool, what kinds of things can be causing the chlorine in our pool to almost disappear overnight?
Quite a few different things could be going on, actually. Do you have a drops-based test kit? The test kit that we think is by far the best is the Taylor K2006 or 2006C (better buy). Not available locally but you can get it through this link that takes you to Amazon: http://pool9.net/tk/
But, in the meantime, go to Walmart and see if they have the HTH 6-Way drops-based kit (no test strips!) and get that. If they don't, get an OTO/Phenol Red kit (yellow and red drops) instead. Use it to test and then post your numbers. Also while you are at WallyWorld, get several jugs of their generic 8.25% bleach, a couple of boxes of 20 Mule Team Borax (laundry aisle) and a gallon of distilled water.
Tell us the kind of pool you have and volume and exactly what all you have put in the pool, meaning ingredients and not just product names like 'shock.'
We also need to know how the water looks and if you have had any algae.
Finally, tell us what size your pump is (hp) and type and size of filter.
Then, somebody here can try and help you.
Welcome to the Pool Forum!
Repost with requested info and then someone here can try and help you.
(Until you registration is completed, you won't be able to see the rest of the forum while you are logged in. So, copy that link and then paste it into a browser window after you log out.)
I am using a Taylor K-2005 complete (high) but I also have a OTO kit, our pool is an in ground plastered pebble tech, 15,000 gallons. The water in the pool looks good, we have only had the very start of an algae, and that was about 10 years ago. The pool has an in floor cleaning system, a Jandy Aqua Pure chlorine generator1400. Now for the plumbing : the main drain is on a separate 1-H.P. pump and goes to a Jandy DEL 60 filter, the skimmer runs on another 1-h.p. pump that also runs the in floor cleaning system and runs through the Jandy 1400 cell on the return line after it goes through a Jandy CJ250 filter, we have had the 12 years now, through these years about 8 or 9 times a year I would put a pouch of Kem-Tek shock Quick (trichioro-s-triazinetrione), outside of that the only things I have added is Natural Chemistry pool perfect+ phos free, about 8oz. every 10 days and Muriatic acid once or twice a week.
Pool analysis report from Leslie’s Salt: 3000, Cyanuric acid: 90, PH 7.4, total alkalinity 90, Phosphates: 0, total available chlorine: 1.5, free available chlorine: 1.5 calcium hardness: 480.
Now yesterday evening: I put in two gallons of liquid chlorine; (sodium hypochiorite) I guess just hoping for a fresh start. I will let you know in a few days if it made a difference.
Also what is this for? generic 8.25% bleach, a couple of boxes of 20 Mule Team Borax (laundry aisle) and a gallon of distilled water.
Thanks, Chuck
Ps we can’t do much about the hard water It’s just our water here, but it’s worked fine in the past.
Bleach is sodium hypochlorite but just at a different concentration that what your liquid chlorine. Borax is used to raise pH but for now, just put it on the shelf. A pH at 7.4 is just fine. We use distilled water at times when we have to do dilutions for some of the chemistry tests so we advise buying it to keep on hand.
Can you use your K2005 kit and run the tests and report your numbers, please? We typically don't trust pool store testing as we find that in many cases it is not accurate.
One reason that you are losing so much chlorine may be the fact that your chlorine level has dipped so low and you may be on the verge of an impending algae bloom that you can't yet see. Needed chlorine levels are based on CYA levels. More about this connection can be read in the chart at this link:> http://pool9.net/cl-cya/
Once we verify what your CYA reading is with your kit, you can use the info in the chart to see how high your chlorine levels should be. I advise you to go ahead and shock the pool up to the appropriate shock level based on the chart. Do you still have more of the pool store chlorine? If so, what percentage sodium hypochlorite is it, how long have you had it and where has it been stored?
With high CYA and the high chlorine levels that are needed as a result, you need a kit that can measure them. Since you have the Taylor K2005 kit, you don't need to buy a whole K2006 kit. You can just buy an add-on kit -- K1515 or 1515C -- which will give you the missing chlorine test that can measure past 5ppm that your K2005 kit does not have. It is available through the same test kit link I posted above in the previous post.
Until you are able to get the K1515, you can use your OTO kit to estimate high chlorine levels by using the colors on this chart to decipher off the scale readings:> http://pool9.net/oto-chart/
Repost with K2005 readings and info about your liquid chlorine.
(I have no idea what Natural chemistry pool perfect+ is nor what its affects on your water's chemistry will be. What are the ingredients?)
Hello,
I bought the chlorine yesterday afternoon and yesterday evening at 6.00pm I scattered it throughout the pool and spa and ran both pool filters for another 6 hours, this morning I checked the chlorine level with OTO and it was almost an orange yellow I checked it again at 3:00pm this afternoon and it’s pretty much the same, it is at least up to the 13 ppm color you sent to me on the oto testing chart, and probably a bit higher, the sodium hypochlorite in the chlorine is 10.0%. pool perfect is a product that leslies pools sells, it is to keep phosphates at near zero levels, I’m sorry but the bottle does not show any ingredients.
I tested water with Taylor 2005 kit, like you asked the Cyanuric acid is 80, P-H is 7.6 total alkalinity is 80, the calcium hardness, I’m getting 675 check it twice both times 675.
thanks again, Chuck
Don't use any more of those packs of trichlor. They have CYA in them and your CYA is high enough. Also no dichlor powder (also has CYA) and no cal-hypo because your CH is WAY too high. Best to stick with either liquid chlorine from the pool store or bleach.
You are three hours behind me so still early evening where you are. Go ahead and test your chlorine this evening and then test it again in the morning within an hour of sunrise so you can compare the numbers. That will tell us if you are losing chlorine overnight which would be a sign that you are fighting something in the water.
Did you read the CYA/Chlorine chart I linked above? If not, please do so and also order that K1515 add-on kit. With a CYA of 80, your normal chlorine levels will have to be between 5-10 ALL the time. If you drop lower than 5, you risk an algae bloom. Your K2005 can't test high enough but the add-on kit will give you that ability.
A lack of cyanuric acid (stabilizer/conditioner), especially combined with heavy use or contaminants in the pool can eat up chlorine fast.
Thanks, I am new at this and I didn’t realize you posted this. The pool has plenty of stableizer it is at 80 ppm,
thanks again my friend.
