Re: chlorine
I am using a Taylor K-2005 complete (high) but I also have a OTO kit, our pool is an in ground plastered pebble tech, 15,000 gallons. The water in the pool looks good, we have only had the very start of an algae, and that was about 10 years ago. The pool has an in floor cleaning system, a Jandy Aqua Pure chlorine generator1400. Now for the plumbing : the main drain is on a separate 1-H.P. pump and goes to a Jandy DEL 60 filter, the skimmer runs on another 1-h.p. pump that also runs the in floor cleaning system and runs through the Jandy 1400 cell on the return line after it goes through a Jandy CJ250 filter, we have had the 12 years now, through these years about 8 or 9 times a year I would put a pouch of Kem-Tek shock Quick (trichioro-s-triazinetrione), outside of that the only things I have added is Natural Chemistry pool perfect+ phos free, about 8oz. every 10 days and Muriatic acid once or twice a week.
Pool analysis report from Leslie’s Salt: 3000, Cyanuric acid: 90, PH 7.4, total alkalinity 90, Phosphates: 0, total available chlorine: 1.5, free available chlorine: 1.5 calcium hardness: 480.
Now yesterday evening: I put in two gallons of liquid chlorine; (sodium hypochiorite) I guess just hoping for a fresh start. I will let you know in a few days if it made a difference.
Also what is this for? generic 8.25% bleach, a couple of boxes of 20 Mule Team Borax (laundry aisle) and a gallon of distilled water.
Thanks, Chuck
Ps we can’t do much about the hard water It’s just our water here, but it’s worked fine in the past.
