Re: chlorine
Bleach is sodium hypochlorite but just at a different concentration that what your liquid chlorine. Borax is used to raise pH but for now, just put it on the shelf. A pH at 7.4 is just fine. We use distilled water at times when we have to do dilutions for some of the chemistry tests so we advise buying it to keep on hand.
Can you use your K2005 kit and run the tests and report your numbers, please? We typically don't trust pool store testing as we find that in many cases it is not accurate.
One reason that you are losing so much chlorine may be the fact that your chlorine level has dipped so low and you may be on the verge of an impending algae bloom that you can't yet see. Needed chlorine levels are based on CYA levels. More about this connection can be read in the chart at this link:> http://pool9.net/cl-cya/
Once we verify what your CYA reading is with your kit, you can use the info in the chart to see how high your chlorine levels should be. I advise you to go ahead and shock the pool up to the appropriate shock level based on the chart. Do you still have more of the pool store chlorine? If so, what percentage sodium hypochlorite is it, how long have you had it and where has it been stored?
With high CYA and the high chlorine levels that are needed as a result, you need a kit that can measure them. Since you have the Taylor K2005 kit, you don't need to buy a whole K2006 kit. You can just buy an add-on kit -- K1515 or 1515C -- which will give you the missing chlorine test that can measure past 5ppm that your K2005 kit does not have. It is available through the same test kit link I posted above in the previous post.
Until you are able to get the K1515, you can use your OTO kit to estimate high chlorine levels by using the colors on this chart to decipher off the scale readings:> http://pool9.net/oto-chart/
Repost with K2005 readings and info about your liquid chlorine.
(I have no idea what Natural chemistry pool perfect+ is nor what its affects on your water's chemistry will be. What are the ingredients?)
