Results 1 to 10 of 13
Thread: Water getting slighty cloudy, any ideas
    rdefino is offline Registered+ Thread Analyst rdefino 0
    Jun 2013
    Haverhill, MA
    Default Water getting slighty cloudy, any ideas
    I have an AG 18x34 and the water is getting slightly cloudy. Not sure if I should shock or what. Any ideas.
    Water readings from K-2006
    Chlorine Free 3.2
    PH 7.2
    ALK 80
    CYA 30
    water temp 82
    Any thoughts if I should shock or what?
    Thanks for any advice.
    Oval 18x34 14400 Above Ground Dough Boy, DE Pentair
    Default Re: Water getting slighty cloudy, any ideas
    Go ahead and shock it. Use the chart at this link:> http://pool9.net/cl-cya/
    Keep the chlorine at shock level until you meet 3 criteria:
    1) You lose no more than 1ppm of FC from sundown one evening to within one hour of sunrise the next morning
    2) You have no higher than 0.5ppm of CC
    3) The water is clear.
    Run your pump 24/7 while you are trying to clear the pool, cleaning your filter as needed.
    Go ahead and run the CH (calcium hardness) test one time. Although vinyl pools don't need calcium, sometimes if it is high it can cause problems. Also, did you run the CC test when you did your FC test?
    By the way, what are you using as your source of chlorine? Your CYA is pretty low. Are you having trouble making it through a hot sunny day with a chlorine reading?
    Hope this helps.
    (Hint: Use a 10mL sample instead of a 25mL one. It will make your chlorine testing reagents last longer. You'll multiply the drop count by 0.5 instead of 0.2.)
    Jun 2013
    Haverhill, MA
    Hi, thanks for the reply.
    I did not do the CC when doing the FC. I will next time.
    I was using just straight chlorine 3in tablets, but I just started using HTH 3in tablets with stabilizer and algecide.
    I have a straight stabilizer, should I use it with the HTH tablets?
    I wouldn't use the HTH tablets at all. We don't recommend any type of algaecide except 60% Polyquat and even then, most pools don't need it. I never use it in my pool.
    The other trichlor tabs that you have --- check the ingredients and make sure they don't contain copper. If they don't, you can use them but you can't shock a pool with trichlor tabs. To shock the pool, you can just use bleach. What is your volume?
    Jun 2013
    Haverhill, MA
    Really? I have a hug tub of the HTH tablets and rather not dump them.
    Volume ~14000 gal
    Jun 2013
    Haverhill, MA
    How much bleach do I need to shock with?
    In a 14K gallon pool, each quart of 8.25% bleach will add 1.5ppm of chlorine and each of the 121-oz jugs will add about 5.5ppm. Shock level is based on your CYA reading so with a CYA of 30, you'll want to add enough bleach to take your chlorine level up to 15ppm.
    Jun 2013
    Haverhill, MA
    Should I use a stabilizer also? Can I use Diclor instead of bleach?
    You can use dichlor instead of bleach to shock with but just be aware that most dichlor that is sold these days has unwanted stuff blended into it. Two that we know of that are safe to use are listed on the following page. http://pool9.net/ssr/
    If you use trichlor or dichlor, you won't want to add the stabilizer since both of those products have stabilizer (CYA) in them already.
    Jun 2013
    Haverhill, MA
    Hi there,
    I picked up some bleach to shock with. I do have a gallon of Poolbasics Stabilizer, Cyanuric acid 25% Inert Ingredients 75%.
    Should I add the stabilizer with the bleach, or before, then add bleach?
    thanks
  1. Water is a little cloudy, a little help...
    By iBrew in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-19-2011, 01:54 PM
  2. Water with Green Tint, any ideas
    By atomasze in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-09-2010, 07:49 AM
  3. Ideas for pool with low water level at opening
    By jeremyweber in forum Pool Equipment & Operations
    Last Post: 05-31-2010, 07:23 AM
  4. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
  5. Reduction of Backwash water loss ideas.
    By JohnT in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 07:30 PM
