Re: Just Embarking on the BBB Method - Help Needed
Thanks Watermom,
Shock level - is that around 15ppm? I seem to recall reading that somewhere on the forum.
There is so much info on the forum that my brain gets full and then I can't find what I need later.
You said "I would wait until you take care of the algae problem." Are you saying (I hope) that by keeping the CL up to shock levels the junk on the pool sides should disappear or are you saying that even though the water is clear I still have an algae problem?
CBean
