Results 1 to 10 of 23
Thread: Need advice on cloudy Intex Pool . . . but I don't want a K2006
    Default Re: Need advice on cloudy Intex Pool . . . but I don't want a K2006
    Ellen, if you are able to buy the K1515 kit I mentioned above, that will give you the ability to test accurately and we will be able to help you clear your pool up. Let us know.
    My first pool was an Intex donut, 15' diameter, 15 years ago we used for three years.
    I went thru many of the same problems you did...wasting money on "How To Tame The Pool Monster" and other useless, expensive industry advice. I put in the wrong chemicals, the wrong algaecide, but nothing worked.
    Then, in the 2nd season, I found the Pool Forum. I was one of the first members to have an Intex anything, and Ben knew little about it and was highly skeptical I'd be able to make it work with the as-yet-unamed BBB system in a 3500 gallon fish bowl with a lousy undersized cartridge filter. But I bought the equivalent of the K-2006, and it was the best investment I ever made! My water troubles with the Intex were over, and after the 3rd season I built my current pool and managing it was easy.
    But here is the thing: We can only give you our best advice. You can take it or not take it, because it is your pool, not ours. We hope you will take it because most of our members are able to enjoy their pools with minimum effort and expense because our advice is the simplest, most logical, and effective you can get.
    Jul 2014
    RI
    Thank you all. I DO understand that you can only give me your advice and can't read my total chlorine without the K2006. I never asked you to find a way around it or guess. What I just didn't appreciate was a moderator coming down hard on me (or changing the name of the thread). This pool has been a good intro to the whole process. I especially never knew that places like Leslie's were like when I'd take my car to Jiffy Lube for an oil change and they'd try to flush my radiator for $300.
    Virginia
    +1!
