Thread: Pump motor making clicking noise
    Mar 2012
    Default Pump motor making clicking noise
    Hi,
    I just replace my pool pump motor, I got a marathon electric motor, it is wired for 220 and when I turn it on, it starts making a noise like a click that is on and off.
    The diagram on the motor says that there is a voltage selector but I have not been able to find it
    I can send a video if that will help.
    http://www.rulosworld.com/pool/20140802_181125.jpg
    http://www.rulosworld.com/pool/20140801_201423.jpg
    http://www.rulosworld.com/pool/20140801_201414.jpg
    http://www.rulosworld.com/pool/20140801_193715.jpg
    http://www.rulosworld.com/pool/20140801_193642.jpg
    Default Re: Pump motor making clicking noise
    Sending the video would be OK. Posting it on YouTube and linking to it would be better.
    I'd have to check the manual to be sure about the voltage selector. What model motor is it? If you're not sure, link to a picture of the motor label (not the pump label).
    mas985's Avatar
    Pleasanton, CA
    It could be that the centrifugal switch is engaging and then disengaging for some reason so make sure that it has a full range of motion and the contacts are clear and there are no obstructions interfering with the switch.
    Mark
    May 2010
    I think you were sold a used/rebuilt motor. Your pictures do not look like a new motor. You probably only have a 30 warranty if that. Quick, take it back!
    4 out of 3 people have trouble with fractions.
    Factory Warranty/Service for: Jandy, Pentair, Sta-Rite, Raypak, Polaris, and Paramount pool cleaning systems.
    Good point!
    Thanks.
  1. my pump is making a funny noise
    By newtothis in forum Pool Equipment & Operations
    Last Post: 11-22-2012, 11:10 AM
  2. Pool pump making humming noise then shuts off
    By Campbell in forum Pool Equipment & Operations
    Last Post: 10-30-2012, 11:36 PM
  3. AO Smith Pump Making Noise...
    By rarely in forum Pool Equipment & Operations
    Last Post: 06-11-2012, 08:55 AM
  4. Pump making whining noise
    By monkeyratman in forum Pool Equipment & Operations
    Last Post: 09-04-2007, 09:09 PM
  5. Pump making loud buzzing noise
    By Islander2C in forum Pool Equipment & Operations
    Last Post: 06-18-2007, 09:41 AM
