Here's a thread where an Intex system was adapted to a Summer Escapes pool.
http://www.poolforum.com/pf2/showthr...ilter-amp-pump
I'm pretty sure all Intex SWCGs include a copper ionizer. Copper can stain pools and turn light hair green. It is effective against algae, but not so much with bacteria. If you keep enough chlorine in the pool to prevent bacteria, that's usually enough to prevent algae. Soooo, you might want to see if you can safely disable the copper ionizer.
Good luck!
Pappy
