Closed Thread
Results 1 to 10 of 14
Thread: First Post: Constructing a low cost pool for a fitness club
    Pool Masters and Hustlers is offline Commercial pool users, operators, owners Pool Masters and Hustlers 0
    Aug 2014
    United States
    Default Re: First Post: Constructing a low cost pool for a fitness club
    I couldn't have found a better person to talk to about such an issue. You are right based on what I know most people do not actually use the pool. Its a shame what fitness clubs, health centers, gyms have become. I can't say I'm too proud. If your advice is to do it the right way well than thats the way I'm going to do it.
    So what do you do now for employment?
    I'll create some scenarios where I do not include a pool in my business plan. Although the places I would like to compete against I would have a advantage over them if I offered more services and amenities. This is going to be an interesting 3 years. If you could summarize why its so difficult to build a pool, I'm still having issues grasping the concept. To me it doesn't make sense why an item thats designed to hold water, keep it at a certain temp, filter it, and so forth has to cost so much? Must have something to do with the support structures that hold the water together? and all the reacquiring costs of maintenance? as well as the cost of materials to build the pool? but why is it so much?
    Why can't we just get a hallowed out metallic tank, add some filters, add some temp controllers and some support beams and fill that with water? I know I probably struck a nerve with that but why can't there be an reasonable solution.
    Also I would like to be a little more serious with this forum if you could bump me up. Trying to edit the profile to give you guys what you want.
    Nope. Sorry.
    Commercial pool Q & A is low priority for me. It's what I do locally, and I'm *very* familiar with the problems, issues, and solutions. But none of those things mix with the forum well, nor do responses here serve the forum generally.
    Given that my time is limited, I'm simply not willing to put more into answering your questions. There are pool designers and consultants available: you may want to spend some time with one of those.
    Good luck . . . and I'm done here.
    Quote Originally Posted by Pool Masters and Hustlers View Post
    I'm probably going to regret this, but you need to learn a LOT more about pools before you are even READY to explore building one for your "health club".
    To give you SOME idea of what you face: A 60'x20'x4' deep pool contains 156 TONS of water--that's right--The water ALONE weighs as much as 78 automobiles! Plus water is reactive with almost everything--so protection of the structure is critical from corrosion.
    Quite frankly, I use my local YMCA for a gym, but if they had a pool like you describe, I'd be out of there like a shot!
    Just my 2 cents, and I'm NOT in the pool business.
    Aug 2014
    United States
    I just don't understand why its so hard to find information on this topic. I try to tell people I'm serious about doing this and every person has basically laughed in my face.
    Yeah I know I'm inexperienced. Don't really have the capital to do this. Probably way in it over my head. But can't someone dream? can't they at least try to learn the craft. I am at a big disadvantage and I understand that.
    Knowing a little bit about my circumstances is anyone willing to point me in the right direction? Everyone is saying it cannot be done, what if I told you it has to be done... than what?
    Your question is sort of like asking, "How can I buy and have delivered, a pro-quality lifting bar and a full set of plates, from 10 lbs to 100bls each, for $100?"
    I promise -- we'll spend more on YOUR question, when you *successfully* answer the one above. OK?
    Seriously, dude -- listen to yourself! You were ENTIRELY correct, when you wrote:
    But you were only half-right when you wrote this:
    You ARE at a big disadvantage, but you do NOT understand it: if you did, you'd understand what we've been trying to tell you somewhat politely.
    So, it's time to be "FranK" rather than polite: It is NOT possible to build a functional indoor lap pool in the US for $25,000. And, you're being dumb by continuing to ask. Come back when you have a budget of $300,000 for a CHEAP indoor lap pool! That *might* be possible.
    Aug 2014
    United States
    Alright. I may be able to bring about $100,000 for the pool. but if thats 1/3rd of what it takes to maybe make it happen than I will hold off for sure... Where can I go to calculate the costs of making a pool? thanks.
    Let's just leave it right there, and stop wasting your time, and ours.
    . . . Thread closed . . .
Closed Thread
  1. What kind of pool did you get and what did it cost?
    By Derek O in forum In-Ground Pool Construction and Repair
    Last Post: 07-18-2013, 12:50 AM
  2. Constructing 12x24x54 AG on our own... are we done yet?
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 07-20-2007, 02:20 PM
  3. In Ground Pool Cost - Which Cost the Most?
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 08-04-2006, 05:31 PM
  4. Sams Club Pools?
    By badkins in forum Above-Ground Pool Construction & Repair
    Last Post: 05-02-2006, 05:10 PM
